T56 questions
Old Jun 14, 2022 | 03:06 PM
Austin Tikki Wiggins's Avatar
Default T56 questions
There's a local 2004 CTSV t56 for sale for a really good price. It only comes with the bellhousing and nothing else. I have a L96 6.0, and I was wondering what all I would need to get this working behind it. I've already read about either replacing the tail housing with a GTO or go with an adapter for the flange. Is there a certain pilot bearing and flywheel needed? I know there's 2 different sizes of pilot beatings. But I'm trying to find a budget minded clutch kit with a flywheel. Is there a way to relocate the shifter without machining the reverse shift rail?
Thank you for any advice!
Old Jun 14, 2022 | 04:28 PM
AMP-D's Avatar
What are you trying to install it in?
Old Jun 14, 2022 | 05:33 PM
It's going in a 1970 monte carlo
Old Jun 14, 2022 | 07:22 PM
AMP-D's Avatar
It can be converted to a GTO style unit. You will need the output shaft, extension housing, shift rail and offset lever replaced.
Old Jun 17, 2022 | 09:09 AM
innerloop's Avatar
I can't offer any advice on the conversion, but if you move forward, I would be interested in buying the CTS-V specific shift stuff that you take off.
