MityVac question, is this normal
It is a Tick Performance Master Cylinder if that matters and I did replace the zip ties with hose clamps. I'm going to bleed it the traditional way later on today once some help comes over, I just wanted to know if anyone knew what was going on with the MityVac.
Yes, I have read and read about this. Some seem to have luck and some don't.
Anyway, my magic sinking pedal ended up being fixed with two things:
(1) I pulled the master cylinder (Tilton) and found it full of a black sludge. That sludge was sometimes blocking the fluid return. The hose between the master cylinder and the fill reservoir was breaking down and formed that sludge. I cleaned out the cylinder and replaced the hose. Then I flushed the **** out of the system hoping none of the sludge was stuck in the slave cylinder.
(2) The pedal still sometimes wouldn't return all the way and I was out of ideas. On the advice of Tick, I removed the helper spring from the pedal. That fixed the problem for whatever reason and it's never come back. I actually like the feel better now, I get more feedback in the bottom half the pedal.
If you put a vacuum on the clutch fill bottle then it will pull air past the seals and you'll get bubbles until you stop. Everything above the bore of the master cylinder is just reservoir and doesn't seal against much pressure or vacuum.
Gravity bleed the lines to pre-fill and then snap the hydraulic line to the transmission. Then get the *** end of the car high in the air so the nose of the trans is pointing downward. You gotta do this to tilt the slave cylinder so the bleed port is higher than everything else, otherwise air gets trapped. Pedal bleed with smooth, slow strokes. Never open the valve unless there is pressure on the pedal, and always close the valve with the pedal still in downward motion moving fluid. If you push the pedal too fast then it will emulsify the bubbles into a millions of little teeny tiny bubbles that are hard to purge. If that happens then just walk away for a little while until all the bubbles collect into bigger bubbles.
I'm still battling this clutch bleed. I was thinking it was a bad slave until this morning I went out to check the fluid and it was black, so I sucked some out and refilled it. This is when I noticed a black sludge coming out of the reservoir. I'm beginning to think I have your sludge problem and need to spend a weekend thoroughly bleeding and cleaning.
https://www.thirdgen.org/forums/ltx-...ml#post6331422
I have a new GM slave ready to go in and I am researching a new clutch also. Just don’t want to take the plunge until I’m sure this is what I need instead of a cheaper fix.
