Pilot bearing needed for clutch install?
I'm getting ready to do a clutch swap on my '00 LS1 with a little less than 50K on the clock. I'm just waiting for the parts to be delivered. I will have all this by the end of the week:
'01+ slave cylinder
'01+ master cylinder
new stock flywheel
pressure plate
clutch disc
throwout bearing
alignment tool
Clutch is a spec stage 3. I was just wondering if I need to replace the pilot bearing for a new one since I've been searching and came across this. Never really got a definite answer if it is mandatory or not though. What exactly is it and do I need to swap it out?
'01+ slave cylinder
new stock flywheel
pressure plate
clutch disc
throwout bearing
alignment tool
Originally Posted by Krab
Is it that small cylinder shaped object that comes on the end of the alignment tool? It's about 3/4" tall and about 1" in diameter. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
