4 Speed or 6 Speed?
The 5th and 6th speed on a 6 speed are overdrive gears for gas mileage, so you'll see them come into play at higher speeds, giving you better mileage and lower RPM on the highway. Other than that, they aren't going to deliver anything for you on the lower end.
You can play around with various transmission ratios and see where your top speeds will be. With the prices people want for 4 speeds these days, I'd rather just go for a TKX or, since your project is a truck, a 6 speed out of a Frontier.
A T56 6-speed is like a 4-speed in terms of useful power gears. 5th and 6th are just overdrive for cruising. So maybe the real choice here is do you want overdrive or not?
I don't own any manuals anymore due to health issues so when you look at the big picture, just be happy you can use a clutch. I miss mine.
The aero is garbage, I’ll give you that. But keep in mind this isn’t going to be a stock truck. Coils up front, custom 3 point in the rear, putting an ls7 with hopefully a 12:1 cr in it for the power plant. This is going to be the nastiest NA Silverado around. I want to push the envelope, not worry about what’s realistic.
4 speeds have a 1:1 4rth gear and that is no good for high speeds. If you gear the rear to suit that, it will be a dog off the start.
T56 is what you need.
As far as gearing you'd want a deeper first gear to compensate for the taller rear gear and as a result you'd tend to have a wider ratio spread within the transmission. Wider ratios mean more RPM drop between gears which is something to consider. For reference a 2.66 1st (available in T56s and similar in various 4 speeds) with a 4.10 rear axle will have a 10.9:1 effective take off ratio. If you do a 2.9 1st (another readily available 1st gear option common between T56s and Jerico/T101As) with a 3.42 rear axle you end up with 10.26:1. Both result in the 10:1 to 11:1 first gear final drive range which is an okay general starting range. If you go much taller (less than 10:1) then taking off will not be as easy/smooth and conversely going much deeper (more than 11:1) makes for a very short 1st gear.
If you wanted a straight cut 4 speed another option would be a T101A/GF4A. It's based on the T10 (similar to how a Jerico is based on a Ford toploader) and generally it's a bit stronger than the Jerico tends to be. They also have a ton of gearing options including going down to around 3:1 for first gear.
If you really wanted to get creative you could adapt a gear vendors unit to make a straight cut gear dog box with overdrive. Jericos are relatively simple since GV has a housing for them. However they do not make a T101A adapter and in my conversations with them they never will. I just finished modifying a GV T10 adapter to work with the T101A I'm putting in one of my cars. It's quite a bit of machining to make work since you have to contend with 4/7 holes shifting in the mounting pattern, a much taller reverse idler gear stack than a ST10, the reverse shift lever needs modification, and other random assorted bits of clearancing. This will not be the cheapest option by far unless you fall into a string of random craigslist and ebay deals like I did. I'm in this transmission for less than a TKX not counting the labor in machining the adapter or the other things I did like rebuilding the transmission since that was me doing it for fun.
The T56 isn't a bad option it's definitely going to be the more typical transmission used in a performance LS application. I've had multiple T56 cars and have an S1 shifted T56 magnum for a different project, they're awesome transmissions and would be more civilized than the options above for around town use.
The Frontier 6 speed or Z car CD009 variants are also pretty strong with kits readily available to adapt to an LS motor. I had a 6 speed Frontier for a few years and loved that transmission.
At the end of the day you could make any of the above options work in some form. The main thing you really need to consider is what it will be used for the majority of the time, your budget, and how much effort you really want to put in it.
