clutch went to the floor?
Old 07-26-2004 | 09:22 AM
1BadAzzWS6's Avatar
Default clutch went to the floor?
First off I've got the Spec Stage 3 clutch with about 12k miles on it. So I went to do a burnout yesterday on the street. I rev it up a bit, pop the clutch, and the rear tires start spinning as usual. The car starts going sideways, I slam into second gear and the car revs high and I get the feelings that my tires aren't spinning b/c usually it gets traction thru second. So then I get that feelings that my clutch isn't grabbing at all, then I notice my clutch pedal goes to the floor. I immediately let off the gas and push the clutch in and out a few times and it comes back with some pressure. I stopped in parking lot and let it sit for a minute and it seems alright, but now I have some chatter in the clutch, where there was none before. I've never had any probs like this before. What would make it do this? It definitely scared the shyt outta me...I hope I didn't hurt anything.
Old 07-26-2004 | 11:40 AM
badpewter-z's Avatar
LS1TECH Sponsor
when you put the clutch in did you drill mod the master? upgrade the slave?
very common issues when these are not done
