Hard to shift when stopped
Old Nov 7, 2023 | 12:31 PM
Mgill's Avatar
Default Hard to shift when stopped
So I just got my car back from getting the magnum F installed, I had issues with it shifting before the trans was swapped. So RXT clutch, McLeod flywheel, new slave, new master, and tick speed bleeder. Measured for a shim and came up with needing a .115 and that put the air gap at .161 woth shim installed. Not sure if it needs to be bleed more or what. Clutch engagement is very low on the pedal and it's very hard to get into first and reverse when the car is stopped.
Old Nov 21, 2023 | 08:51 PM
Rt Jam's Avatar
There should be no air gap. It needs to be preloaded.
Is it hard to engage a gear with the engine off?
Where is pedal when the clutch starts to engage? Should be half or close to top.
