TR6060 procedure to reinstall bellhousing
Cant figure out how to put back on my bellhousing to trans TR6060..the shifter shaft/rod seems to stick out to much and its blocking the bellhousing from going back in.
Does the shifter shaft has to be in a specific position??
Car is a 2013 Camaro 1LE. Trans front cover(bellhousing) has the plastic pump and shifter shaft bearing.
hey there sorry for bringing this back up but I just pulled my bellhousing of a tr6060 not knowing it was integrated and I can get the bellhousing back on but the shifter doesn’t not feel right at. Very sloppy. I don’t know where I went wrong
