Not another pilot bearing thread
Old Feb 11, 2024 | 12:29 PM
69ChBuLQ4's Avatar
Default Not another pilot bearing thread
I have been mocking up my tkx behind a 6.0l LQ4 using a speedway motors ls swap steel bellhousing. I measured the snout stick out of the trans from the face of the bell housing and I am getting 1/2". This puts me in a weird zone for both pilot bearings, I have looked at the information on choosing the bearing based on 1/4-3/8 (large pilot bearing) or 3/4-1" (small ls10 pilot bearing) sitck out. I installed the big bearing to give it a shot and the transmission slides up flush, but the splined part of the shaft is butting right against it. Plus, the bearing is riding on maybe 3/8 with there being a cut part of the shaft before it transitions to the splines. The small bearing would take about 1/2" of the shaft with 1/4" of that bearing not being used. I have seen some people say there is a mid range bearing but the stuff coming up shows its for SBC BBC motors. Any words of wisdom would be appreciated I'll see if I can get some pictures for this long winded post.
