TREMEC fluid for stock T56
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
its 2024 and I'm back in an F-Body (2000 Camaro SS) after selling my last car in 2018. I've tried all the synthetics and fancy fluids out there in my past F-Body T56 cars and every time its lead me back to good ol cheapo DEXRON III being the best. However, i see that TREMEC has their own trans fluid now and was wondering if any of you guys have tried it in a stock T56 with the OE paper/fiber synchros? any good?
if not, what's the consensus go to fluid nowadays for a stock T56? thanks!
The following users liked this post:
Coy (02-15-2024)
Pennzoil Syncromesh has always had god like qualities for me.
Othwerwise it's plain ole Valvoline Dexron III
High load/endurance applications can benefit from the thicker fluid which has a better heat breakdown factor. I think you already know from experience that heavier fluid equals harder shifts.
I am at my own debate with this myself and might run Syncromesh in my rebuild after the break in with DEX 3. I’d like to avoid using a cooler if possible and maybe that is where the 75W85 will come into place.
While my 94-97 style T56 was made in 2004 it had the carbon ones per D&D where I bought it in 2005. They told me about the fluid compatibility differences at that time.
I use DEX3 but have used Redline D4, a synthetic, which was very good and also made cold shifting less "notchy".
I've been using Redline D4 ATF for 20 years and stick to it. Tick likes to recommend Schaeffer's oil
https://www.schaefferoil.com/204-atf-supreme.html
