newbie clutch install question - slave spring & pressure plate contact
haven't built a GM platform manual setup in the past, been BMW's and a Miata in the nearest past
do I have an issue if my slave spring had to compress slightly when installing my trans?
Mating my AR5 to my LQ9 using the FABbot adapter kit. Everything seems fine, EXCEPT what threw me off is the spring on the slave. I confirmed correct engagement in the pilot bearing using sharpie on the shaft nose, but I had to pull the trans together the last 3/8"-1/2 gently using bolts to overcome the minor spring pressure of the slave.
After pulling it on and off 5x and saying WTF, I was able to confirm the slave surface (green arrow) was contacting the pressure plate fingers and had to compress slightly (red arrow). Its easily compressible by hand way further than I needed so intuition says it doesn't matter, but I haven't had a setup like that before? Dowels started to line up, I was definitely mostly mated before bolts did anything.
Slave was bought right from FABbot for their adapter kit. Clutch is a LUK that matched the F-body part numbers they say are needed. I am pretty confident its the right clutch setup. Everything bolted up happy, I'd just hate to find out its F'd later when it's easy now to yank the whole package back out if needed
normal, or something weird going on?
thank you, that was my gut feeling as well but worth asking about
adjustable master is a new concept to me, i'll look into it. nothing on this build is standard, so clutch master is still entirely up in the air
Take the spring off the slave and seat it fully down the the TOB. Reinstall and measure the air gap. That's the only way to know for sure if it's correct. Check with the clutch manufacturer on what the air gap is supposed to be....it's usually a .120-.200" spec range for most of the clutches I've seen.
