Transmission Troubles
Trans issues I have:
• Third will grind into gear and has to be held to stay in gear
• 4th likes to lock down the trans and will only let it shift into neutral and third
• When it locks i cannot move to 1st and 2nd or 5th and 6th
I’ve been told multiple things it could be such as; clutch forks, trans keys, and the 3rd and 4th gear itself. I am at a complete loss and Ive been around several forums trying to figure this out. Anything will be helpful. Thank yall so much
Drop the trans and send it to someone like Trick performance for a rebuild
Take it to your mechanic, have them drop the trans and send it to the shop of their choice for rebuild
Look around wherever you live for a shop that works on manual transmissions. Get billet keys also when it is being worked on
