Sticking clutch pedal
Because this is a common thing, here is a link with a bunch of good info about your situation
https://ls1tech.com/forums/manual-tr...-write-up.html
As for the clutch starting to engage after a moment, I had the same issue years ago. My problem was a bad master cylinder that allowed fluid to leak past the seal when the clutch was engaged. Did you measure your clutch clearances when you installed the clutch? Are the hydraulics stock or upgraded?
