T56 clutch issue
Old Aug 19, 2025 | 11:01 AM
UtubeCertified's Avatar
Default T56 clutch issue
Hi all, first post on here but I’m needing some help diagnosing an issue before I start buying parts. Everything was normal until pulling onto my street last night the clutch pedal went to the floor. Pulled it up with my foot as I’ve read about this issue before (master cylinder) and after I pulled it up it is now stuck in the “up” position. It has about an half inch of travel then stops hard. Not sure if this is a MC issue or something internal such as the slave or throw out or clutch itself. Any help would be appreciated. Thanks
Old Aug 19, 2025 | 05:23 PM
the_merv's Avatar
Veteran: Air Force
Have you tried YouTube?
Old Aug 19, 2025 | 05:32 PM
Yes and haven’t found anything on why the clutch won’t depress now
Old Aug 20, 2025 | 11:54 PM
JoshHefnerX's Avatar
If your clutch line popped out of the slave cyl it would do that. Gonna have to climb underneath and see if it's loose.
