Hard shifting t56
while shifting as u pass through neutral there’s a tight spot as u start to go into the next gear. Also, with rear jacked up when u push it into the “tight spot” the rear tires will make half rotation or so but once in gear u can even rev it and tires will not spin. 6th gear from 60 the clutch does not slip and has never slipped for me. This has been an issue when trying to shift fast or at higher rpm as most times will force a money shift.
trans issue or issue with clutch somehow?
If you had a leak even if there wasnt fluid puddles showing up under the car ventually you would need to add fluid.
