Is there such thing as a manual trans cooler ?
When I drive my T56 hard ... I can really feel the heat in the car and against my legs. This is worrying me and I don't think its normal. So has anyone tried or know how to cool a manual transmission ?
I think if your trans is getting that hot then you definitely have a problem. You might want to check to see if you still have plenty of lube in it. Also, are you sure that it is the trans and not the exhaust? I've never heard of anybody cooling a manual trans, although it is technically possible. Find out what's making it run so hot (if anything) and fix it. That'll solve your problem.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You'd need some sort of pump to circulate the fluid.. because the transmission is splash lubricated. I don't see it hurting anything.. but I think your problem lay elsewhere.. Does your tranny fluid look burnt?
Good Luck,
Josh
Good Luck,
Josh
Good Luck,
Josh
Good Luck,
Josh
Thanks for your help
Oils cooling is standard fare on race cars . Especially road course -driven ones. A pump , circulating lines and a heat exchanger are needed. It is somthing best left to the expertienced if you want it to not cause a problem.
Mine gets pretty hot also. I can feel it coming from the gap in the rubber boot of the e-brake. Not sure why it gets that damned hot but I have wondered about this too. What could cause it to start getting that hot. I've got a D&D tranny so if there is a problem I might have to call them and find out if this is something that happens often.
