Dropping the t56???
Old Aug 10, 2004 | 08:32 AM
bengeeee's Avatar
Default Dropping the t56???
Ok guys i did a search first for what i thought would be an easy find but didnt find anything. My 98 Z28 M6 is having synchro problems and i need to get it fixed. I can however save myself a lot of money if i drop it myself. Does anyone have a write up with pictures that could assist me? I have a manual but it would be a lot easier if someone had one online with pictures and detailed directions. Also... my throwout bearing seems to be dead. How difficult is that to change. Btw... i'll have to do all this work on jack stands as i dont have lift access. By the time i get started i will have power tools though.
Much thanks appreciated to all that help,
Ben
Old Aug 10, 2004 | 11:33 AM
Camaroholic's Avatar
It's really not *that* bad. Drain the tranny, remove the torque arm and driveshaft, remove the Y-pipe (if it's in the way), remove the shifter, remove the crossmember, let the trans droop down (maybe put a jack stand with a piece of wood under the engine oil pan to help support the motor), detach the clutch hydraulic line, unbolt the trans from the bellhousing, and pull it out. I've done it on jackstands, you need to get the car pretty high in order to slide the trans out from under the car. I used to roll the trans on to a piece of plywood and drag the plywood out.
Back when my car was close to stock, the above took about 3 hours. Now that I've moved the torque arm, gone to no Y-pipe (bullets), it takes about 20 minutes (with my lift ).
Old Aug 10, 2004 | 02:12 PM
racecar's Avatar
Definately put a jack and a big piece of wood under the oil pan when you unbolt the crossmember. It is not a good thing to have the motor hanging on the front motor mounts.
IF you replace the throwout bearing, don't depress the clutch pedal
unless you have a spline tool installed in the clutch disc and pilot bearing. Without a spline tool, the clutch disc will drop down, and you will never get the trans back in.
Good luck. P.S. After years of getting debris in my eyes, I always wear safety glasses when I am under the car on a creeper.
Old Aug 10, 2004 | 07:22 PM
bengeeee's Avatar
Thanks guys... so would you u reccomend that i just use the chiltons manual i have? I was hoping to get something more detailed. Im surprised no one has made one up yet.
Ben
Old Aug 10, 2004 | 09:37 PM
wrencher's Avatar
wrencher
Look at the install articles on www.installuniversity.com & www.ls1howto.com if that helps too...
Old Aug 10, 2004 | 10:46 PM
bengeeee's Avatar
thanks but unless i missed it neither of the two sites have a write up. Im just nervous because this is my first time dropping my tranny. I dont want to mess anything up... or should i say anything else up lol.
Old Aug 10, 2004 | 11:16 PM
DanZ28's Avatar
If you go to McLeod Clutch Install at install university they show and explain the tranny removal as well as the clutch...
Dan
Old Aug 10, 2004 | 11:26 PM
wrencher's Avatar
wrencher
Ls1 howto doesnt have one my bad but other does^^^
Old Aug 11, 2004 | 01:33 PM
bengeeee's Avatar
oh thx guys.
on me (= ,
Ben
Old Aug 11, 2004 | 02:18 PM
bengeeee's Avatar
Originally Posted by bengeeee
oh thx guys.
on me (= ,
Ben
oo oo... one more question ... In the end section they said to leave the spring out heres a pic ( http://www.installuniversity.com/ins...slaveparts.jpg ) and im not too sure why or even if thats the right spring? Can someone enlighten me on this. Why would i not install that part?
Ben
Old Aug 11, 2004 | 06:58 PM
BLOWNMERO's Avatar
I can pull my tranny out in about an hour or so.. Its actually really easy if you ask me. I just get under it and rest it on my chest.. then put it on the ground. Putting it back in isnt quite as easy though.. for me at least..
Old Aug 12, 2004 | 02:07 AM
bengeeee's Avatar
Holy crap doesnt it weigh like something rediculous? Im a 150 pound 5 9 20 y/o. Would i survive lol?
Old Aug 12, 2004 | 03:08 AM
onyxxtreme's Avatar
probably, bengee....but you'd also probably have a few cracked ribs LOL
when we dropped my trans, a buddy of mine did that method and i helped him rest it on the ground off his chest.
but he's like a 6' 250lb farm boy, so he's probably wrastled bigger steer
one thing i did to move the trans around was to drop it on a big, thick piece of slick/glossy cardboard. Worked like a charm, dragging the cardboard out
