Uh oh stuck in 4th
Old Aug 30, 2004 | 12:19 AM
Luvstruck's Avatar
Default Uh oh stuck in 4th
How do I get it out, and what needs to be replaced? It's been getting there slowly, but I guess I slammed fourth a few times too many. 02 Z28 Thanks, Luvstruck
Old Aug 30, 2004 | 12:21 AM
BadAndy's Avatar
Shift fork is toast, and you may have popped the key out of fourth gear as well. You want it out, your not going to get any cooperation. Just make it happen.
Old Aug 30, 2004 | 12:42 AM
Luvstruck's Avatar
Default Bad Andy
I've rebuilt other transmissions,. but don't know about the T-6. Can you recommend a book or video? Also are you saying to force it out now, or when I get it apart?
Old Aug 30, 2004 | 02:10 AM
BadAndy's Avatar
Well, to be honest, I haven't cracked one open myself, but I have blown a couple up. Couldn't recomend a book for you and most shop maulas I've seen have plety of diagrams but no real instruction. I would recomend you talk to CamaroHolic. He knows this T56 stuff he can probably swap syncros and gears and bend spoons with his mind. I think it's going to have to come out of gear to be disassembled anyway. I think the parts you've screwed up have already gone to ****, so I wouldn't worry about damaging them much more.
Old Aug 30, 2004 | 07:32 AM
calhoon's Avatar
There is a PDF manual on the Tremec site ( download free) Don't let anyone sell you one. Tho get it out of gear : depress the clutch and slowly let it out(engine running) while you attenpt to pull it out of gear. Just reefing on the stick wont do it and it may damage it more. It may have bent or broken a strut if you have been yanking on it awhile in which case a teardown may be the only way to get at it.
Old Aug 30, 2004 | 08:14 AM
SapphireHawk's Avatar
https://ls1tech.com/forums/manual-transmission/155591-attn-camarohaulic-rebuilding-tranny-myself.html
