Clutch stopped working
Old Sep 5, 2004 | 03:51 PM
SloZ06's Avatar
Default Clutch stopped working
Last night my clutch would not engage and let me change gears. For a few weeks now I have noticed it was getting harder to shift at higher rpms. Then finally last night it just wouldn't let me go into any gear. When I turn the car off I can shift gears and use the clutch easily. I can put in 1st with the car off then try to start it and it just tries to jump forward like we were push starting it. It has spec3 /stock hydraulics
Old Sep 5, 2004 | 11:12 PM
tomss99's Avatar
same **** as me dude and i changed the hydraulics.... all i can tell you is that spec clutches are pieces of ****!!!! im putting in a ram right now but i need to find out how to make my master cylinder adjustable for it to work....and i dont plan on buying a mcleod which goes for 310 bucs
Old Sep 15, 2004 | 10:37 PM
SloZ06's Avatar
I found out what it was!! The spec puck had welded it self to the Fidanza aluminium flywheel. I was told this combination would be fine?( guess not)
I am going with another spec3 clutch w/matching spec flywheel. Hopefully this will work a little longer.
