Clutch Problem HELP!!!!
Old Sep 8, 2004 | 08:27 PM
Thor98T/A's Avatar
Default Clutch Problem HELP!!!!
Ok I just had my Spec stg 3 installed by a reputable shop here in town and now my petal is mushy and I have to use both hands to shift it into Reverse. Why is this?? I have all new hydrualics. Please help me
Old Sep 8, 2004 | 08:50 PM
LS1PoweredZ28's Avatar
It sounds like you need to bleed your hydrolics, that should solve the mushyness. You can do a search, there are tons of bleeding methods. I don't know about the reverse problem though.
Kevin
Old Sep 8, 2004 | 08:55 PM
Camaroholic's Avatar
The reverse problem would be the reverse lockout solenoid. It either got left disconnected, or a pin inside the connector got bent (it happens). You'll need to check the solenoid on the reverse lockout... it's on the passenger's side rear of the trans, up near the shifter.
Old Sep 8, 2004 | 09:06 PM
ataylors's Avatar
make sure they used the shim.. And bleed the system
