will drill mod help shifting
Old Sep 9, 2004 | 05:59 PM
Jimmy's Avatar
Default will drill mod help shifting
I am having problems shifting at high rpms with my new spec stage 2 clutch. I can shift from 1st to 2nd but when i try to shift to 3rd it just wont go in. Under normal conditions, it goes in. I did some research and i was thinking that maybe the drill mod would help but i thought that was done to cure the problem of the clutch pedal sticking to the floor at higher rpms. I know 3rd gear can be hard to find but this is a different feeling. The clutch pedal pressure is pretty firm and the engagment is about like stock now, so i thought the hydraulics were bleed good. I have the upgraded hydraulics.
I was going to try to bleed it again and see if that helps. Will the drill mod help? Any suggestions would be helpful.
Jimmy
Old Sep 12, 2004 | 10:28 PM
pimpmaro's Avatar
Well the drill mod shouldn't hurt. If I were you, I woulda done it when I put in the spec.
