Quick disconnect wont come apart
Taking the trans out of my 2000 Camaro I could not get the quick disconnect to let the line go so I started to pull the tranny back and busted the steel tube off that goes into the slave cyl. Now what do I do? I took the master out to do the drill mod and the hole looks like its 1/4 inch already...what gives...
wrencher
Your gonna need a new slave cylinder. To romove them sometimes it helps to push the line into the recepticle & push the white collar in.
The resstriction you need to remove is down from the master end a couple of inches.
Look here www.installuniversity.com go to LSX cars & look in the install documents & go to the transmission section for the drill mod.
I had to pry the fitting off with some pliers (no white collar on mine) then replaced the slave.
It sucks when stuff breaks...
2000, broken, camaro, cylinder, disconnect, disconnects, ford, line, manual, motor, qiuick, quick, slave, transmission, trasmissin, wont
