Replace clutch disc only?
Old Sep 26, 2004 | 02:37 PM
96zvert's Avatar
Default Replace clutch disc only?
I had recently put a Mcleod kevlar/organic clutch assembley in the car, but didn't realize i had a leaking seal on the transmission input shaft. So after the clutch has been slipping alot lately, i pulled it out, and it had tranny fluid on the disc. The setup only has about 5k miles on it. My question is, can I just put a new disc in, or should i go with a whole new setup again? The seal was replaced, but the pressure plate and flywheel have a slight glazed look to them from slipping. What should i do?
Old Sep 26, 2004 | 03:43 PM
LS1x2's Avatar
Formerly 4mulaJoe
I think i would call Mcleod and go with their recommendation.
