SPEC stage 4/4i
I see ALOT of info on the spec 3i, and found several posts on the 4/4i. My question is, how is the 4/4i on the street? Has anyone driven a 4 vs a 3? From the few posts I found, the 4 isn't bad on the street at all. Why is it not recommended for street use? Will the 4i wear a lot quicker than a 3i or something?
thats the stage 5 and that direct from QMP project formula here the site if you want to check it out www.ls1motorsports.com
- Matt
Can you PM me a price on a stage 5 w/ steel flywheel and a 3i with a steel flywheel? (Still debating which route to go) Do the SPEC packages with flywheels come balanced? How would I go about getting it balanced if not? Thanks.
