Clutch Bleeding Procedure?
Luke
www.installuniversity.com www.ls1howto.com there's stuff in there thats helpfull.
Get the new slave from GM or a sponsor they are all the same now basically.
I drilled a small hole in my floorboard, and bleed it by myself. Hold pedal down, crack open/close bleeder valve, pull pedal up. Pump 5-10 times, hold pedal down, crack open/close, pull pedal up. Repeat until pedal is stiff. Works fine for me.
