Best Clutch?
Old Oct 5, 2004 | 07:32 PM
02 Camaro SS's Avatar
Default Best Clutch?
What's the best clutch to handle 430 rwhp on slicks? i would prefer one with good streetability but my main concern is one that could hold the power w/o trouble and would not cause any problems along the drivetrain.
Old Oct 5, 2004 | 08:22 PM
Mike K.'s Avatar
spec 3
Old Oct 5, 2004 | 08:24 PM
nspr8td lt1's Avatar
Originally Posted by Mike K.
spec 3
spec 4, stage 3 specs crack around the spring area under launching even on drag radials. stage 4 is unsprung and is very similar in driveability to the 3.
Old Oct 5, 2004 | 08:47 PM
BuckeyeROC's Avatar
King of Pigskin Knowledge
Are the stage 4i and stage 5 similar then in drivability since there are no springs on either?
Old Oct 5, 2004 | 09:13 PM
JL ws-6's Avatar
Race your car!
I'll be installing a 4I in a few weeks, I'll let you know how it is compared to a stock clutch. As for drivetrain damage... with slicks and a clutch... better get a good driveshaft and a 12 bolt/9 inch.....
Old Oct 6, 2004 | 05:18 PM
So a spec stage 4 seems the best way to go. i got a custom steel driveshaft already and i'm on my second 12 bolt. hopefully that will be the end of my problems. i have a cartek clutch and i've heard that on average, more than half of them are out of balance and that may be responsible for broken rears
Old Oct 6, 2004 | 05:31 PM
Redbird87's Avatar
I was just logging in to ask about clutch suggestions
Also, I've talked to a few people who recommend upgrading to an '02 throwout bearing and master cylinder (my car is a '99). Anybody done this? Recommend it?
TIA
