Unbalanced driveshaft?
Old Oct 6, 2004 | 09:30 AM
Ellis Juan's Avatar
Default Unbalanced driveshaft?
My stock tranny mount was ripped so i replaced it with a prothane from Tracing. Took it for a test drive: 1st gear-2nd(vibration decreases thru the gears) feels like my dshaft is unbalanced(lot of vibration). Did a search and a lot of guys get vibration but does it feel like what im talking about. I think i will shim the crossmember down a bit. Kinda makes me nervous. Any thoughts on what it could be? My guess is that it is higher than stock and picked the back end of the tranny up a bit.
Old Oct 7, 2004 | 09:32 AM
Steve Burger's Avatar
LS1TECH Sponsor
If the shaft is not balanced the vibration will increase with speed. Did it vibrate before the trans mount change?
Old Oct 7, 2004 | 09:54 PM
Ellis Juan's Avatar
no, only after the install. Its weird im kinda used to it now, doesnt feel as bad. I guess it really does just transfer drivetrain vibration that bad.
Old Oct 8, 2004 | 08:30 AM
LS1TECH Sponsor
Mine does not do this. I would double check everything.
Old Oct 8, 2004 | 11:31 PM
black00TA's Avatar
its going to vibrate a lot at first, then it will settle down, also check to make sure you didnt add or forget a washer. because if its not the same height than you can throw off the angle that the input shaft goes in and improper driveshaft angle
