Where do you put the Shim for a Spec 3?
My spec 3 clutch did'nt come with instructions of any kind.
The metal shim, I"m thinking it goes between the Tranny housing and the Slave... am I right?
I kept reading about the "green" shim.. but mine did'nt come with anything green... It's just a silver piece about a 1/4" thick and it has two slots on the sides for the bolts to go through for the Slave...
The last Spec I saw installed had that metal shim instead of the regular green paper material one. This was about 3 weeks after I installed my Spec 3 with the green paper type.. I kinda wish I wouldve got the metal one.. when installing my Spec 3 I was kinda worried about the green one fatiguing over time.. unlike a metal one.
*edit*
The metal one is no where near 1/4".... not even close.
*edit*
I dont have the peice in front of me right now, the car is up in the air at the hobby center on base, so I'll mearsure it tomorrow.
I'm sure your right it probably is thicker...
Yes it's only 1/8" thick, I checked today... Spec is closed over the weekend, so I dont know if they sent me the wrong one or not...
This clutch install is still kicking my A$$, wish I would have just got it done at a shop somewhere...
10 Second Moderator
Originally Posted by badpewter-z
the only time ive seen a metal one is on the stg 5's
