Clutch problems under WOT
Old Oct 6, 2004 | 03:41 PM
navy02ws6's Avatar
Default Clutch problems under WOT
After 2 or 3 6000 rpm shifts, my clutch seems very weak. It doesn't return to its normal position, and feels very spongy. I don't have that many power mods, and only 27000 miles on the car, so I would've thought it would last longer than this.....anyways my friend says both my clutch and all of my hydraulics are worn out.....the fluid looks fine, and I only have this problem when I shift at a high rpm. Aren't hydraulics supposed to be fine from the factory on 01-up cars? Also, I've never gotten any smoke or smell from the clutch. Could this just be the return spring? If it is hyrdraulics, shouldn't this be covered under warranty (assuming that they don't void it for mods)? Also, has anyone ever gotten a dealer to warranty a clutch?
Old Oct 6, 2004 | 05:27 PM
Dal1as's Avatar
I'm having the exact same problem with similar miliage. Did the drill mod, and have bled the hell out of the clutch. Clutch still goes soft after high RPM shifts. I'm beginning to think it's the slave on mine.
Old Oct 6, 2004 | 05:31 PM
str8b4llin's Avatar
i fart sumtimez....
