slipping stage 3
Old Oct 9, 2004 | 11:00 AM
slow trap's Avatar
Default slipping stage 3
i just installed it over 2 months ago.car is an 02 broke it in easy for 400 miles and then done 5 or 6 5000+dumps .a week later i was in a parade and had to slip it alot.well last night went to track on 27-10.5-16 et streets,side stepped@4500,spun alittle then hooked but every time about 20 feet out it would slip rpms up to 5000+ for a bit while then drop back to 4000,then when i hit second it would hook and pull then slip.i crossed the 1/8 in second at 92.5 mph.i aint gonna say how bad it was when i tried the nos.is my clutch crystallized and glazed over?can i drive iy awhile and wear it off or is it screwed?thanks for the help.
Old Oct 10, 2004 | 02:39 PM
joeformula's Avatar
I've got about 400 miles on my stage 3 and am planning to drive the car hard next week, by that time I'll have about 800 miles on the clutch. I was going to ask if I should add more miles before I slip the clutch. But I'll just wait and see what they tell you.
Old Oct 11, 2004 | 10:07 AM
Keenov's Avatar
Do you guys have vibration when shifting to 1st? I just put mine in and it vibrates the whole car when shifting to first :/
Old Oct 11, 2004 | 11:26 AM
peterock98's Avatar
Mine does the same thing & it get worse when i'am turning.
Old Oct 11, 2004 | 05:22 PM
joeformula's Avatar
Mine does that too, I thought it was the tranny mount.
Old Oct 12, 2004 | 09:25 PM
SpdfreakLS1's Avatar
Ive installed 5 stage 3's, ive had 3 myself. i sprayed on the first right after i put it in, the second i broke in, the third i dont really care. they have all been great
Old Oct 13, 2004 | 03:37 PM
slow trap's Avatar
i was in a parade 2 weeks before i raced it and had to slip it alot so i believe it got glazed over.maybe i can wear it off and be ok .
Old Oct 16, 2004 | 06:20 PM
IrateTA's Avatar
I'm starting to have some slipping problems myself - I just installed the stage 3 a couple weeks ago. It holds pretty well in 1st, 2nd, and 3rd... if its in 4th, 5th, or 6th and I mash on the gas, it slips.
Any ideas from people with experience?
Old Oct 16, 2004 | 07:51 PM
Kevyn's Avatar
My stage III just started slipping in the upper gears. I assume it's time for another clutch.
I got one summer out of this clutch. That makes 2 specs in 2 years for me.
I am tired of pulling my trans. Anyone know a clutch that will last more than one season.
I'm running street tires and go to the track about two or three times a year and I go right thru these clutches.
Old Oct 16, 2004 | 09:24 PM
IrateTA's Avatar
yeah, its totally wierd - it holds reasonably well in first, but if its in 6th and you slam the gas = major slipping...
Pulling the trans = goat *****
Old Oct 20, 2004 | 05:01 AM
JMBLOWNWS6's Avatar
Man I guess I just joined the Spec slip club But mine did 20 k before dieing. I am going with the 3I
Old Oct 20, 2004 | 07:08 AM
1ScrudeDude's Avatar
You guys with slippage.....have you been intentionally slipping your clutch?
Just a thought. All my racing will be with 3500 rpm clutch dumps. I can't afford to keep buying more clutches.
Old Oct 20, 2004 | 08:50 AM
IrateTA's Avatar
I've only gone down the 1/4 mile 3 times after installing the new clutch and I dumped it around 2500-3000, so I guess its hit-or-miss.
Old Oct 20, 2004 | 02:26 PM
ws.6kid's Avatar
Im on my second Spec Stage 3. If your clutch is slipping in high gear its more than likely your clutch going and if your slipping in 1st it is totally gone. I went with a ceramic spec stage 3 and it seems to be holding up pretty well after 5k miles.
Old Oct 20, 2004 | 04:31 PM
NastySSoo's Avatar
I use a sintered iron disc clutch. Hundreds of passes and daily street driving and it has NEVER slipped. Ive been racing on ET Streets also.It doesnt even chatter bad. My.02
Old Oct 20, 2004 | 09:10 PM
SMOKIN01TA's Avatar
i have the stage 4, you can slip it dump it and whatever else to it and holds great. i have 25 or so 6000 dumps on it plus my street miles
Old Oct 20, 2004 | 11:17 PM
Krab's Avatar
I wonder why the hell so many spec 3's are starting to slip after a few thousand miles. I sure as hell hope mine doesn't crap out on me. Dropping the tranny is by far the worst part of it. How does everyone start rolling out with this clutch (slip the clutch a little, or just plain dump it and lunge forward)?
Old Oct 20, 2004 | 11:31 PM
Orange Crush 408's Avatar
Mine was three weeks old with about 10 6000 dumps on it and 5 races. Broke it in for 450 miles now this evening it is into the rivets. I am thinking of going to the stage 5. Any suggestions?
Old Oct 20, 2004 | 11:49 PM
z383stroker's Avatar
I;ve heard alot of problems with people having oil on the cluctches from there hands and thats why there slipping. I talked to mark at spec and he said you should clean the flywheels and the clutch pressure plate with mineral spirits or acetone. To remove the grease. Just a thought.
Old Oct 21, 2004 | 12:24 PM
slow trap's Avatar
i made sure mine was totally clean.i only intentionally slipped my clutch in the parade i was in.i don't think mine is wore out,i believe it was crystalized from having to ride it so much.it don't slip on the street so i can't tell if it is better now,i'll have to wait for the et streets and the track.
