dhaving trouble getting in reverse
Old Oct 11, 2004 | 09:07 PM
WS6FirebirdTA00's Avatar
Default dhaving trouble getting in reverse
ok ive got a spec stage 3 i put in the car in may. it seems to be having trouble getting into reverse sometimes. i have to put the tranny in 1st and then reverse but its being a bitch. i dont know if it has to do with the clutch or what? sometimes goin in 1st or 2nd its a pain in the *** too. what can it be ?
Old Oct 11, 2004 | 11:11 PM
Full-Force's Avatar
when u find out let me know cuz mines a bitch to get in reverse
Old Oct 11, 2004 | 11:51 PM
00BadaSS's Avatar
Default tranny
if ur having trouble with all the gears ur clutch may not be fully dissengaging, u could probably fix that with an adjustable master. if its just reverse it could be that synchro or maybe the shift fork too
Old Oct 12, 2004 | 06:14 AM
i think my friend just had his tranny rebuilt and is still having the same problem, so im confused
Old Oct 12, 2004 | 07:20 AM
calhoon's Avatar
rebuilding atranny will not help a poorly releasing clutch. When the box was put back in was the wiring connected properly? It is easy to mis-connect the solenoid leads.
Old Oct 12, 2004 | 06:21 PM
it goes in reverse after a little bit of work. he is h aving those troubles and the clutch was ruled out of it
Old Oct 13, 2004 | 11:03 AM
calhoon's Avatar
What about the solenoids/ connection? It is hard to miss damaged synchronizer teeth on a rebuild- do you trust the job?
Old Oct 13, 2004 | 12:58 PM
Krab's Avatar
Why not start with the small things. First bleed the system, and make sure all the connections are good. If the problem is still there, then move onto something bigger. Are you on the stock clutch/hydraulics?
Old Oct 13, 2004 | 03:30 PM
clutch is new since may, hydros are too, its all bled right, was fine after i did the clutch and just started to act up in the past maybe month or less
Old Nov 9, 2004 | 03:46 PM
jrtf83's Avatar
i have the same problem getting into reverse, but only occassionally, it seems that its worst when the car is cold.
Old Nov 9, 2004 | 06:26 PM
mine is better now, try to get the car in 3rd before u put it in reverse and it should slide right in there
Old Nov 10, 2004 | 12:49 AM
screamin00ss's Avatar
mine goes in reverse, but it grinds some of the time, sometimes i have to put it in gear 4 or 5 times before it finally works, and it only does this when its cold...any answers?
Old Dec 22, 2004 | 06:04 PM
jrtf83's Avatar
i HATE this about my car, i've resorted to opening my door and pushing my car back. so embarassing!
Old Feb 6, 2005 | 05:17 PM
jrtf83's Avatar
bump, this is still making me mad
