Which Throwout Bearing?
I bought a Spec 3 clutch that included the throwout bearing. I also bought updated slave and master cylinders. The new slave came with the throwout bearing attached. My question is should I use the bearing from Spec or just leave the one that came with the new slave attached and use it? I am assuming they are the same part.
