High performance clutch?
Old Oct 13, 2004 | 05:36 PM
v DaN 02's Avatar
Question High performance clutch?
Hey, i was wondering if anyone could recommend a good high performance clutch....
also i have a clunking noise when i shift into first from a dead stop.... somtimes happens when i am moving shifting to other gears, clutch is fully depressed kind of turns my stomach somtimes.... any advice?
brand new clutch 2k miles on it? new pressure plate and flywheel thanks in advance
Old Oct 13, 2004 | 10:20 PM
greekss's Avatar
spec stg 3... good price and decent holding power dont forget u will need updaded hydros.
Old Oct 13, 2004 | 10:23 PM
v DaN 02's Avatar
any others?
Old Oct 16, 2004 | 01:04 PM
mike c.'s Avatar
i've been using the ram 980 clutch with great results. i had problems with my past ram 910 clutch,but found out it was not the clutch at all. i had to buy a adj master and do the drillout mod. once i did this i've had no problems at all. 10.8 1/4 times with the front tires off the ground.
Old Oct 16, 2004 | 03:15 PM
02WS6Bird's Avatar
Exedy or McLeod Twin Clutch...Spec Stage(s) 2-3-4
Old Oct 18, 2004 | 02:41 PM
v DaN 02's Avatar
any other clutches out there? no specific price range....
what should i try to do to eliminate the clunking noise when shifting into different gears? should i try getting a new slave? or try doing the drill mod(not sure what this is)? please post pics if you have any....
thanks in advance
Old Oct 18, 2004 | 02:48 PM
ls1fbod's Avatar
Centerforce (Dual Friction)- is a great clutch and engages better than others. $500
Spec- Heard lots of great things, but never road in a car that engeges like centerforce.
Old Oct 18, 2004 | 02:50 PM
v DaN 02's Avatar
any other views on centerforce?
Old Oct 18, 2004 | 07:49 PM
KALEL's Avatar
spec stg 3 is nastyness... that clunking noise could be a throwout bearing...is it only when you shift or is it when you take off from first gear??
Old Oct 19, 2004 | 02:47 PM
v DaN 02's Avatar
its only really when i shift, i thought the throwout bearing was replaced when my clutch was replaced by Chevy so i dont think its the bearing
who makes a centerforce clutch?
