Drill mod?
DO NOT DRILL THE END WITH THE QUICK CONNECT. If you do you will be buying another new MC.
maybe my stupidity helped clear up others questions.... sorry for being precautios... dont wanna screw anything up...
Also put a small dish under the end of the master cylinder as it will leak a couple of ounces when the AN4 line is removed and that is a painted surface.
Also I could not get a .125 drill bit in the line at all. I used a 7/64 which was the largest that would fit. Also be careful not to lose anything (like a drill bit) down the line while you are probing for the fitting <g>.
Now on the bleeding. Is there a fitting up there like the bleed fitting on the brakes to put a line over or are we expected to just get brake fluid all over everything. Thanks
Perry
