Anyone use a flywheel shim?
NOT the slave shim that came with my Stage 3. The machine shop had to take nearly .030" off my flywheel. I know Spec says not to take more than .015" or so. The guy ordered me a .025" shim to go between the crank and flywheel which should almost put it back to the original depth. I've seen it on older cars, but has anyone ever done this on an LS1?
Just get a stock flywheel from SLP i picked one up for $75 off there site.
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
It's a perfectly valid way to bring the flywheel back to where it should be (plus or minus five thousandths, eh.)
There is nothing special about an LS1. It's still a crank, a flywheel, a pressure plate and a disc. The same theories apply.
Originally Posted by ws.6kid
I shimmed my PP but i wouldnt shim a Flywheel cause it spins and could possibly break that shim off and that would not be good...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But with a doweled 6 bolt crank flange, the likelihood of a shim breaking off would hinge upon one thing: improper install. And there's not much way to screw it up. So no, that's not going to happen.
Originally Posted by jmd
The hydraulics may suck in these cars and break a lot of stuff in the process.
I'm gonna try it since I already paid for the resurface and the shim. It can't break off or fall out and I shouldn't have any problems....shouldn't. If it doesn't work, I'll buy a new one.
were can you get shims? I may need some to get the clutch relationship just right on a custom project? Can you also get shims for the slave calender? as I may need to use the GM .4" spacer as well, and one spacer is bad enough if I need to go more maybe I can shim out the throughout/slave cylinder?
Project 04 colorado, 4.8L V8 from 07 GMC van, stock MA5 asisin 5spd whit advanced adapters bell housing, stock colorado slave, same as 98-02 fbody. Flywheel from a 98-02 fbody, Z06 pressure plate and disk
anyone no if the F-body flywheel will work with the truck 4.8L motor?
It is worth noting that shimming the flywheel forces the ring-gear farther from the crank. This can affect the interaction of the r-g and the starter bindex. Just be careful...otherwise you can damage the teeth.
Do you guys carry shims for the flywheel, if I need a little bit more? Or do you have shims for the unitized throughout bearing/slave cylinder combo?
We do not offer any flywheel based shims though we do provide a shim the goes behind the slave. These are .115" or .188" in thickness. You mention the flex-plate...but this would be removed when moving to the manual transmission any way. If you removed .030" from the flywheel then you could cut a thinner shim from gasket material and put it in with the shim that was originally included in your clutch kit. Let me know if you have any further questions. Thanks,
Yes I am removing the flex-plate and installing a advanced adapters chevy small block to AX-15 bell housing adapter. And hopefully use a 98-02 camaro flywheel with a corvette Z06 pressure plate and disk. The AA bell housing is 7 an 1/8" deep
-My transmission is a Asian MA5 5spd from a 2004 colorado same bolt pattern as a AX-15, my input shaft is 8.2" long
-My engine is a 2007 4.8L from a GMC van, 6 bolt pattern crank shaft with 26mm long bolts
- In order to maintain the original drive shaft length and shifter position of the Colorado I will need a 3/8" inch spacer between the bell housing and the engine
-Also for information purposes the ma5 input shaft is 8.2" long the AX15 is 7.875" long but the AX15 adapter is meant to bolt on to a Gen II small block, if using a newer LSx series engine the crank is .4" shorter so 8.2 - .4 = 7.8" only out by .075" pretty damn close if you ask me!!
So now I need a 3/8" spacer between the bell housing, which means I also need a 3/8" crank to fly-wheel spacer, GM makes a .4" spacer 3/8" is .375 " so I am out by 0.025 + .075 from above = 0.1" Looks like I need a throughout bearing spacer around 0.1"
Some thing else to consider is that the advanced adapter bell is meant for an aftermarket external slave setup. I plan on using the Colorado internal slave, which is the same part number as the 98-02 T56 slave cylinder.
No one has done this before, it may not work, I definitely will need to adjust something, just seeing what options there are for doing so.
If I need to bring the slave closer to the pressure plate I would like to use slave cylinder shims. If I don't have any clearance with the slave in its shortest position, then I will either have to machine the fly-wheel or the back side of the slave cylinder
My questions;
-what length bolts would be required to be used with the .4 inch fly-wheel spacer, with a 98-02 camaro flywheel?
-Will a camaro fly-wheel work on the 4.8L motor?
-are there .4" longer pilot bearings available?
-Do you carry 3/8" spacers to go between a GM bell housing and the engine block?
-what should the air gap be between the face of the throughout bearing and the clutch fingers? 1/8" I am going to guess?
this is all very complicated, and I think I have a pretty decant grasp on it, it fascinates me to do something that no one as ever done before! Anything that I am overlooking or not thinking about?
My questions;
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
