View Poll Results: Your Spec setup
Stock Flywheel, no shim, new hydraulics.
2
18.18%
Stock flywheel, shim, new hydraulics.
2
18.18%
New flywheel, no shim, new hydraulics.
1
9.09%
New flywheel, shim, new hydraulics.
0
0%
New flywheel, shim, new hydaulics, no break in.
1
9.09%
New flywheel, shim, new hydraulics, ~500 mile break in.
5
45.45%
Voters: 11. You may not vote on this poll
Spec Problems? Please come in.
Old Nov 2, 2004 | 04:11 PM
black_z's Avatar
Default Spec Problems? Please come in.
I have been reading a lot about spec problems, and it seems that they are really hit or miss. When you vote, please explain your entire clutch setup and your breakin procedure (or lack of) im trying to figure out if there is a pattern to why people are having failures. Thanks.
Old Nov 3, 2004 | 11:50 AM
IllusionalTA's Avatar
W/ spec it don't seem to matter what combo of new part's shim's and what not you have.. Its really a hit/miss thing..
Old Nov 4, 2004 | 05:09 PM
black_z's Avatar
All these spec problems and only 2 votes? Lets figure out where the problem lies.
Old Nov 4, 2004 | 08:20 PM
probably has somthing to do with: Cheap Blanks, Small Springs, Improper material, **** Poor R&D, They do have great customer service.. Will send out a new clutch w/ no quip's or quam's as long as you send the original p.o.s back.. I'm not making a blind statement either..
Old Nov 4, 2004 | 08:22 PM
Here's one of my SPec Stage III's after 2500miles.. and 4 Launches on a 300rwhp car.. Had 900 break in miles on it along w/ 1800 everyday driving mostly on hwy from NY to VA..
Attached Thumbnails Spec Problems?  Please come in.-face-pp.jpg   Spec Problems?  Please come in.-flywheel-side-disk.jpg   Spec Problems?  Please come in.-front-pressure-plate.jpg
Old Nov 4, 2004 | 08:50 PM
SilverGhost's Avatar
Motorboater
seems most people with problems are trying to use the stock flywheel.
i voted the last option in the poll.
i drove my car probably 3,000 miles this year and made a couple hundred passes on slicks launching at 7,000+ rpm with my 3i and billet f/w with zero problems what so ever.
Old Nov 5, 2004 | 06:04 AM
The LS1 Spec's seem to fair alot better and fail less frequently then the LTx one's.. Hit or Miss...
Old Nov 5, 2004 | 09:25 AM
1SLO-LS1's Avatar
I went with every recomended upgrade when installking my 2 spec stg 3's. Both have been proffesionally installed, broken in. Both clutches have been a miss. Extremely loud squeaking when car is cold when clutch engages, extreme chatter that spills drinks and sounds like car could shake loose. They said they would take care of getting my clutch righ though, I would have to take it out and ship it.. Atleast they answered my letters, whish is a good sign, but the clutch is simply crap . Everyone I know with one has same problems I do. My first one broke with no track passes and 5K miles on it, this clutch has 2 passes on it and 8K miles and I have to replaceit due to drivability.
Old Nov 5, 2004 | 07:55 PM
StoreKeeper99Z28's Avatar
Thumbs up
I had the same problem.
I now have a ZO6 Clutch Kit and have never looked back!
Rx Stores
Old Nov 7, 2004 | 08:16 PM
amwellls1's Avatar
2000 miles and it is slipping at the track. voted the last option. I had more success with the zo6. It is a stage 3 will not hold my et streets launching at the track. Very dissapointed with it.
