Need help with shifting problem
Old Nov 5, 2004 | 09:24 PM
Boosted One's Avatar
Default Need help with shifting problem
I just took the car to the track today for the first time since the t-56 conversion. It has a Centerforce dual friction in it and a stock t-56 with a pro 50 shifter.
Then problem is If I rev the car over 6000 it won't go in gear! It doesn't matter how slow I shift. 4th seems to be the biggest problem. 5 out of 6 passes it missed 4th. I have the drill mod done, a brand new updated slave, and a new master cyl. It's blead perfect (thanx bushman).
anyone know anything that might help. I probablly should upgrade the 3/4 fork but other than that, is there anything else?
I was wondering if the weights on the centerforce were creating to much pressure at high rpm or somthing of that nature.
Thanks for any advise
Frank
Old Nov 6, 2004 | 09:08 AM
necrocannibal's Avatar
Now you know why NOBODY uses Centerforce clutches in our cars. I think the issue can be resolved though by shimming the slave cylinder. Atleast thats what a friend of mine did to make his work. He had the exact same problem and shimming it took care of it.
