SPEC Stage 2 or 3??
Old Nov 9, 2004 | 04:16 PM
White 02 WS6's Avatar
Default SPEC Stage 2 or 3??
Im undecided which stage to get...Alot of people say get a stage 3. I know the stage 2 is rated at 475 RWT and the 3 is 780 i believe...My car is a bolt on car and not nearly putting out the touque that these clutches recommend...I MAY get a cam later and I doubt I will throw gas on the car...Im just worried about it being too much clutch and I dont want the thing to chatter all the time...Need some opinions and which stage to go with...
Old Nov 10, 2004 | 11:37 AM
JL ws-6's Avatar
Race your car!
I went with a 4I... and it really doesn't chatter at all. If I were you, I'd go with the biggest/best that you can afford.. better than having to do it over again later because you didn't go with enough the first time.
Old Nov 10, 2004 | 11:44 AM
chadtn's Avatar
The stage 2 should be fine with no power adders...If you plan on any type of power adder in the future I would go with the stage 3.
Chad
Old Nov 11, 2004 | 12:30 PM
ONGRNGO's Avatar
I run a spec stage 3 with my bolt on car and love it. I have 10,000 miles on it and quite a few passes at the track and no probs. I would say go with the Stage 3 then you don't have to worry about the clutch if you decide to get a Cam or anything else.
Dan
Old Nov 11, 2004 | 10:51 PM
retsell's Avatar
I have a spec3 in the truck and it chatters like a BITCH. Could be my slight difference in weight though...
