question
Old Nov 10, 2004 | 11:14 AM
2001pewterSS's Avatar
Default question
i went to the track last night i ran good but at the end of the track i had to pump my clutch back up any ideas on what is going on
Old Nov 10, 2004 | 11:35 AM
777's Avatar
777
search...this happens to many people and there are various reasons why... i believe the most common response you will get is either your clutch is hot...or not enough hydrolic fluid is getting back into the master cylinder...may not be master but i think it is...drill mod should take car of that though...if you don't know what that is...you can do a search to find detailed instructions on it...basically there is restriction in the hydrolic lines...you take a drill and hollow them out....this allows the fluid to flow more freely...and should clear up they clutch sticking to the floor
Old Nov 11, 2004 | 10:44 AM
Z'mnypit's Avatar
How did you do?
Old Nov 11, 2004 | 11:08 AM
i ran 13.1 about 6 or 7 times
Old Nov 12, 2004 | 08:34 AM
Z'mnypit's Avatar
[QUOTE=2001pewterSS]i ran 13.1 about 6 or 7 times[/QUO
not bad, not bad get you a K&N and a lid and you could hit 12.90's!!! Was this on you 20's?
Old Nov 12, 2004 | 09:19 AM
yea that was on my 20s i still spinning off the line if i take them off and run 16 or 17s i think i run 12s im running 13.1 at 109mph
