Grinding when going into 6th.
Old Nov 12, 2004 | 06:53 AM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
Default Grinding when going into 6th.
Drove to work, let the car warm up, drove off. 4 miles later I'm on the highway and I decide to drop the car into 6th gear at 2,000 rpm and cruise. As I shift into 6th (not a slow or fast shift, just normal), the tranny makes the grinding noise you hear at the track when people miss the shift. Funny thing though is that the tranny does shift to 6th even with the grinding. The tranny would grind at low, moderate and high rpms, even make somewhat of a grinding noise at a stop light.
The car was warm, fluids are full, new Spec 3 iron clutch.
What gives?
Old Nov 12, 2004 | 07:19 AM
METALBEAST's Avatar
Sounds like your 6th gear synchronizer is going out.
Old Nov 12, 2004 | 07:24 AM
badpewter-z's Avatar
LS1TECH Sponsor
joe mine does the same latly thats it s cold as hell out, after a few miles in 5th it willbe fine. does it go away after awhile?
Old Nov 12, 2004 | 07:31 AM
Humanitarian
Well after about 10-15 miles it was still there.
Old Nov 12, 2004 | 10:01 AM
demonspeed's Avatar
It's not mine! woo hoo!
Once and awhile I'll get that too on 2nd or 4th gear. Usually only does it when the clutch is starting to wear out...
