tranny problems
Old Nov 30, 2004 | 12:59 PM
stockredta's Avatar
Default tranny problems
when i shift into second there is nothing it fels like it engages into gear but it doesnt do anything what could be the problem
Old Nov 30, 2004 | 02:05 PM
calhoon's Avatar
If 1st works, its not a broken fork or a broken synchronizer sleeve. You could have sheared the teeth off the 2nd drive gear. This would put alot fo debris in the trans. I would not drive it like that as it could lock up.
Old Dec 1, 2004 | 11:38 AM
stockredta's Avatar
hmmmm so it couldnt be anything else becasue im getting ready to pull trans and would just try and get ready for the money ill be putting out
Old Dec 1, 2004 | 03:43 PM
1madss's Avatar
I had the same problem on my previous rebuild. The engagement teeth were gone on second gear. Labor was 250 and the gear was ~150.
