Double wammy doh!
Old Dec 5, 2004 | 01:22 PM
mikes02ls1's Avatar
Default Double wammy doh!
Well my spec stage 3 is gone with only 6,000 miles, and now my tranny is giving me problems. Want to pop out of third, I think 3-4 shift forks are bent. Hopefully my extended warranty will cover it. Now I need MONEY!
Old Dec 5, 2004 | 09:10 PM
peterock98's Avatar
If you have a aftermarket shifter they will say you modified the tranny and they won't fix it under warranty.Make sure you put the stock shifter on.
Old Dec 5, 2004 | 11:34 PM
mikes02ls1's Avatar
Stock factory hurst is on since I bought it.
Old Dec 6, 2004 | 11:15 AM
BadAndy's Avatar
I left my Hurst Comp Plus shifter on both times they fixed my transmission, along with the cam, the gears, the headers, etc. Just ask Brad if you need to do anything before bringing it in. The dealership gets it's money, and the Serviceman gets his sales up, so most smart dealerships don't mind doing the warranty work on "slightly" altered vehicles. The bill goes to the General. That extended Warranty wasn't cheap, so use it.
