tranns question
Old Dec 10, 2004 | 08:58 AM
arcboy's Avatar
Default tranns question
Does anyone know what the reverse lockout does on a 96 M6?
I thought that it might prevent me from putting it in reverse when traveling forward.
Old Dec 10, 2004 | 01:46 PM
calhoon's Avatar
Actually its called a reverse inhibitor because it does not truely lock you out of reverse. It is the same device that is on all T56's . It is speed controlled and adds a high load to the revese gate above a control speed set by the ECM. Unpowered the load is present so the control signal ( releasing the load) is sent at low to 0 speed.BTW the load is present with the key off as well.
Old Dec 13, 2004 | 04:44 PM
JasonWW's Avatar
I know on the LS1's the "lockout" is just a solenoid that is springloaded to block it going into reverse. Only with the key on and the car under 3 MPH does the solenoid activate to allow reverse to be engaged.
Old Dec 13, 2004 | 06:08 PM
zombiedude's Avatar
"96" m6? or is it a m5.
