Ram Clutches On Special & In Stock @ TSP!
We are running a special on Ram Automotive's Powergrip clutch system. This is comparable to other company's stage 3 clutch systems. It is rated to 500 HP, and it is a dual-sided clutch with a double-sided 300/900-series clutch disk. A billet steel flywheel is recommended for racing and/or high HP street applications for your safety, and their adjustable master cylinder is strongly suggested for racing so minimum release can be set to avoid high RPM shifting problems. If your vehicle does not fit into either of these criteria, then you can use the factory hydraulics and factory flywheel so long as it is resurfaced. Ram's clutches will take a lot more abuse than stock, and they will have EXCELLENT drivability. It will not have the shudder that is normally associated with other stage 3 clutches on the market.
Ram Powergrip Clutch System: $389
Ram Billet Steel Flywheel: $249
Ram Adjustable Master Cylinder: $165
This sale will be good through Sunday, December 19th, and they are in stock and ready to ship.
Jason
Texas Speed & Performance
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
