Flywheel Help!
Old Dec 23, 2004 | 03:29 PM
MadMike93TA's Avatar
Default Flywheel Help!
Whats up guys... I've got a 383 stroker LT4 and a T56 out of an LS1 I would like to link together... Basically what I'm looking for is a 168 tooth 14" externally balanced flywheel thats made for a one piece rear main seal... I'm not sure where to go to find this... The stock LS1 flywheel is 168 tooth 14" but the crank bolt pattern is different and its not balanced for a stroker... The LT1 Flywheel is 12-3/4" 153 tooth and won't work with my Centerforce Clutch for the LS1 T56... Many people say this won't work and many people do... So I'm trying to figure it out on my own... The imput shaft on the LS1 is longer than the LT1, but so is the LS1 Bellhousing, and when you bolt the LS1 T56 to the back of the LT1, there is no clearance problems, the Imput Shaft fits perfectly into the Pilot Bearing on the Crank... anyway I'm just wondering if anyone knows where to find that flywheel...Thanks.
Mike
