Spec Stage 4, need some help
Old Jan 15, 2005 | 04:43 PM
JpowZ28's Avatar
Default Spec Stage 4, need some help
well its getting to the point where im putting my car back together. I just got done putting a H/C setup in the car and now i have to join the engine and trans back together. I was wondering what kind of flywheel you guys are running with the Spec stage 4? And did you install the shim that came with the clutch? and finnally did you improve the Hydraulics at all. thanks for any help
Old Jan 16, 2005 | 04:06 PM
chpmnsws6's Avatar
i put a shim behind the flywheel per machine shop request. 01-02 slave and Mcloed master
stock flywheel
Old Jan 16, 2005 | 07:51 PM
2000WhiteTA's Avatar
Stock flywheel 01-02 Slave and Mcleod master when I had a spec clutch in my car
Old Jan 16, 2005 | 10:42 PM
Turo's Avatar
guys who reused your stock flywheel, how many miles did it have? im debating on wheter or not getting a new flywheel, my car has 60k miles on the clock.
Old Jan 16, 2005 | 10:45 PM
chpmnsws6's Avatar
32k when it was put in
Old Jan 16, 2005 | 11:30 PM
JpowZ28's Avatar
i have 47k on mine, and it dosent look bad, i just want all new stuff in the car so i dont have to worry about it down the road
Old Jan 17, 2005 | 02:11 PM
black_z's Avatar
Get a new flywheel man. Its not worth it to be cheap on a clutch setup.
Old Jan 17, 2005 | 02:35 PM
VINCE's Avatar
Shorty Director
Actually get a Billet Steel flywheel. My Spec 5 ate up my stock flywheel.
