Help!
Old Jan 21, 2005 | 07:02 AM
PonyKiln's Avatar
Default Help!
OK guys here goes... I have no clutch pedal pressure at all. Last night I got stuck at a red light and I couldn't pull it out of gear. So i turn engine off and pull it out of gear. I try pumping the clutch to build ome pressure. No luck, so I put it in second and crank it over and stab the gas I was able to ride home in second gear. I'm thinking hydraulics need to be bled or maybe there is actually a malfunction with my master cylinder or slave cylinder. What do you guys think? Input will be appreciated.
Mods in SIG
Old Jan 21, 2005 | 08:14 AM
FreakZ's Avatar
sounds like the master cylinder. Pop the hood and take a look at the fluid level by the brake booster
