Slave cylinder connection
Old Jan 21, 2005 | 07:10 AM
PaulFLS6's Avatar
Default Slave cylinder connection
I am using an LS6 and T56 gearbox. Does anyone know where I can get the slave cylinder connection from (see pic). Also I am assuming that the top connection is for bleed nipple and the bottom one is the main connection. Can anyone confirm this.
Old Jan 21, 2005 | 08:50 AM
Steve Burger's Avatar
LS1TECH Sponsor
Can't see the pic. But top is bleed and bottom is connection to master. The whole thing is more or less one part.
Old Jan 21, 2005 | 09:43 AM
PaulFLS6's Avatar
I think the picture is attached this time
Old Jan 21, 2005 | 10:24 AM
LS1TECH Sponsor
That is the slave and yes the top is the bleed and the bottom is the connection to the master. This is a one piece unit. It is bolted to the front of the trans and the input shaft goes through the slave. You need to pull the trans to change the slave.
Is this what you are asking, or do you need to know wher to get the hose to connect to the slave? The hose is part of the master cylinder.
Old Jan 21, 2005 | 10:30 AM
PaulFLS6's Avatar
Thanks, that's really helpful.
Now any ideas where I can get the connection?
Old Jan 21, 2005 | 12:36 PM
LS1TECH Sponsor
Ya need the master. The line is not sold seperatly.
Old Jan 21, 2005 | 08:19 PM
P Mack's Avatar
If you need the bleeder valve and the slave half of the quick disconnect I have extras (by my thumb in this pic). If your asking for the master cylinder side, then Steve Burger is right about needing the whole master.
