stock knob fitment on short stick.
stock **** fitment on short stick.
I recently got a short stick, not sure what brand because I got it from a buddies totalled SS and we never knew where it came from. It may be an LSS, not really sure. Anyway, I put my stock **** on it and it wont spin all the way on the stick. With it tight the **** is turned backwards, and I cant figure out how to make it fit correctly. In the forward facing position the **** is too loose.
Just want to know how to overcome this little problem. I was thinking of squirting a little silcone in the **** then I should be able to get a good fit after it dries. Any suggestions?
Thanks
Fry
Thanks
Fry
I used some paper and folded it many times and placed it in the hole before I installed the shift ****. This causes the hole to be more shallow and you can add/remove paper to get it right. You can use other material, I just thought of paper at the time.
