4.8L 5spd skipshift?
Old Feb 2, 2005 | 12:46 PM
matthicks6's Avatar
Default 4.8L 5spd skipshift?
Has anyone ever heard of a skip shift or lockout in a 2004 single cab silverado 4.8L w/ a 5spd. The truck will not let me shift from 2nd to 3rd @high rpm. That is how i lost to a mustang gt
can anyone help me?
Old Feb 2, 2005 | 02:54 PM
8-Pack's Avatar
That wouldnt be skip shift, explain a little better, is it stuck in gear, or does it just not go into 3rd. If it wont let you shift into 3 at higher rpms it is more than likely a synchro going out
Old Feb 2, 2005 | 08:59 PM
matthicks6's Avatar
It shifts fine at lower rpm that's what makes me think that it is not a synchro. It locks me out of third when i am driving it hard. Imean taking the rpm near redline, but I have never heard of a 5spd in a truck doing this. Trust me it pisses me off. The dealership down here says there is nothinf wrong because they could not duplicate it. If you aske me they are full of s**t.
Old Feb 2, 2005 | 09:51 PM
Muffracing's Avatar
The skip shift if for emisions, and as far as I know it doesn't apply on a truck. Go test drive another truck and see if it does the same thing. Sorry, I'm not much help.
Old Feb 2, 2005 | 11:37 PM
BS's Avatar
BS
Definitely not CAGS (skip shift). Need more details such as sound, how it feels, will shifter even move.
Old Feb 3, 2005 | 07:16 AM
calhoon's Avatar
it is a shifter control of sorts. It has a hard time synchronizing at high RPMs but it will work= it just takes longer. BTW, that is not why you lost to a GT.
Old Feb 3, 2005 | 02:22 PM
matthicks6's Avatar
The shifter moves fine, there is no noise. It just won't let me get into 3rd gear.
Old Feb 4, 2005 | 07:16 AM
8-Pack's Avatar
Synchro's,
Old Feb 4, 2005 | 07:31 AM
NHRATA01's Avatar
Skipshift only occurs at low rpms anyways. Its definitely a trans or clutch hydraulic issue i'd say.
Old Feb 4, 2005 | 01:37 PM
dowright82's Avatar
Default I have the same truck . . . .
I also drive a 4.8 5-speed regular cab - my truck never does that, all the way up to 6300 rpm. And yes, that might be why you lost to a GT -
My Transmission is in a few pieces at the shop right now because (while I've never had any shifting problems) recently while my shifter stayed in place, there was a loud clunk occasionally and it felt like something was binding, then popping loose, etc - anyway - I hate the NV3500 - want a NV4500 or (with some extra money for custom install) a T56.
You should get that taken care of - I feel your pain man, and no, it shouldn't be doing that at all.
Old Feb 4, 2005 | 02:10 PM
NHRATA01's Avatar
I was going to add, I have an NV3500 in my blazer, and the guys on the S10 forums say while it is good for up to 300lb*ft, it doesn't like to be powershifted much. So I'd be careful how much racing you do with it.
Old Feb 4, 2005 | 02:24 PM
ohohsilverado's Avatar
hydraulic slave cylinder is my guess. was happening on my camaro right before the thing disentigrated on me. that or the valve in the cylinder is allowing fluid to pass by therefore the clutch is not releasing so you can switch gears
Old Feb 4, 2005 | 10:30 PM
matthicks6's Avatar
thanks for all of your responses. since the dealer down here wont do anything, i will just have to take it upon myself. thanks again for all the advice
CHEVY'S RULE (even when they won't let you shift)
Old Feb 4, 2005 | 11:15 PM
Deckhand's Avatar
