need help on upgrading hydros
I would also recommend upgrading the clutch being the car is a '99. How many miles?
If you don't plan on heavily modding then a Z06 clutch will do you fine, if you are planning on modding then you need to do some research for which aftermarket clutch will match up to your expectations of the car.
Zach
You should have upgraded the slave when replacing the clutch though. The master doesn't need upgraded as it's the same.
Do the drill mod too. I really didn't think it would be as big of an improvement as it is, but boy was I wrong.
